proxy-arp-mode
Enables proxy ARP mode for handling
ARP requests. Proxy ARP is the technique used to answer ARP requests intended for another
system. By faking its identity, the access point accepts responsibility for routing packets
to the actual destination.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
proxy-arp-mode [dynamic|strict]
Parameters
| proxy-arp-mode |
Enables proxy ARP mode for handling ARP requests. The options available
are dynamic and strict. |
| dynamic |
Forwards ARP requests to the wireless side (for which a response could
not be proxied) |
| strict |
Does not forward ARP requests to the wireless side |
nx9500-6C8809(config-wlan-test)#proxy-arp-mode strict
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type none
protected-mgmt-frames mandatory
wing-extensions wmm-load-information
client-load-balancing probe-req-intvl 5ghz 5
client-load-balancing band-discovery-intvl 2
acl exceed-rate wireless-client-denied-traffic 20 disassociate
broadcast-dhcp validate-offer
http-analyze controller
